Acer eRecovery и способы восстановления системы - 430 страница
28 апреля 2018 09:23
#8581
Репутация: -1 Сообщений: 24 |
Цитата: irdis19 Здравствуйте! Есть у кого диски восстановления Acer aspire M3802? Посмотри сдесь Acer® Aspire M3802 Windows® Recovery ISO & Drivers P.S. не реклама) |
30 апреля 2018 18:29
#8582
Репутация: -1 Сообщений: 3 |
Hi, sorry for my English. I came across our forum when I was looking for information on the WSI backup. Hear the case interesting because lenovo also has a backup program and works the same as this acera. The case is complicated as there is no laptop on which a copy has been created. [was stolen] [now I work on dell] I tried to create a similar environment that One Key Recowery [OKR] Lenovo requires. I could not force OKR to run [I can not create and force boot for GPF partition for UEFI] I could not do it in VMware or hyper-V A complicated matter. http://forum.notebookreview.com/threads/how-to-restore-onekey-recovery-function- after-changing-partition-size-y580-and-maybe-others.688883/page-8 My problem is that I have a backeup with wsi files, dsi, 000-> 0XX. I also have RYTOOLS.rar when I run IITT on windows8 and i try clik 'load image' it gets the message "opereation failed! error code: C0000003." no matter if I enter the AIM1R8 chass or not. Should I create a WinRE boot, add a RYTOOLS folder and start to run IITT there? Why is it slashing AIM1R8 [password is the name of the bios?] Would anyone find it helpful to decompress my beckap? I am asking for help, I have important data to copy. Lenovo washes the hand from this OKR program. |
1 мая 2018 00:17
#8583
Wiew, Как восстановить заводскую ОС Lenovo OneKey Recovery (OKR) Сообщение отредактировал tixo - 1 мая 2018 20:40 |
1 мая 2018 02:40
#8584
this link is not helpful. Believe me, if you change the partition layout, you will lose your original system or laptop. The backup is useless. I created a system with gpt partition settings for OKR from lenovo on samsung laptop. I have an OKR program on it and I can create new beckaupy. I have not yet managed to force the boot to boot the system, but apparently it can ploplinux with its plopmenager [it is in the bootns hiren's boot cd but it hangs. I managed to find a plopmenager for the uefi version but it does not correctly detect the partition] if it even forced OKR to run it still needs to be forced to unzip this important copy. Because it spits out an error with copy incompatibility. OKR works so that copies are assigned to one system / laptop.! You will lose your system / laptop, combine it! I did not know if I was good. I think I came across what is this WSI file WSI is a package for WISE PACKAGE STUDIO 7.0 [it has been discontinued and there is no support]. This is the right MSI installer in WSI format, Wise Share Point is needed to install WISE PACKAGE STUDIO 7.0. SharePoint from microsoft requires the minimum windows server 2008 with SP2 I will be creating a machine tomorrow. If anyone had WS and wanted the key to Wise Package Studio 7 then I have instalato and a license key. As for RYTOOLS, I am working with IITT and added WSVD files to the system32 library. As for RYTOOLS, I am working with IITT I have added WSVD files to the sys32 library It works correctly but every time I click on Loade image, I get the answer: "Operation failed! Error code: C0000003." I do not know what I'm doing wrong. Can anyone help? i dont know wher is the button is edited post. but following this trail WSI = Windows Server Image Could anyone check on his virtual machine with Windows Server is there an environment such as Package Studio or SharePoint that uses disk images with WSI, DSI, 000-0XX files? And to make it interesting, the WSVD libraries that are needed for the smooth operation of IITT.exe or the OKR program are from the CyberLink Virtual Disk Driver thanks to the keoan forum user: https://notebooky-forum.notebook.cz/viewtopic.php?t=39332 placed the link to ISO winPE / RE with added IITT [Image It 5 Test Tool] ISO is bootable, Data Recovery Solution works. https://uloz.to/!grmtuMgG/wsi-rec-zip It is worth to run, there is an instruction how IITT works I have only one problem, I use Virtual Disk Image (.DSI) step by step In step 3 I choose backup_000_001_ and when I click Load Image I get "The Image Name should be from 1 to 8 characters". Renaming the DSI file does not work, All other options get random errors "Operation failed! Error code: C00000XX" Would I find a friendly person to help me? I've been fighting three days sleepless. |
1 мая 2018 06:19
#8585
Репутация: 515 Сообщений: 4385 |
Цитата: Wiew Would I find a friendly person to help me? This is a Russian-language site and is written in Russian.I've been fighting three days sleepless. --------------------------------------------------------- ACER 5920G/T7700-2.4Ggz /4Gb/SSD256Gb/GF8600M GT512Mb/W10x64Pro ACER 5920G/T8300-2.4Ggz /4Gb/SSD256Gb/GF8600M GS512Mb/W10x64Pro ACER 5920G/T7500-2.2Ggz /4Gb/SSD256Gb/GF8600M GT512Mb/W10x64Pro Windows 11 - Решение проблем с установкой и настройкой. http://acerfans.ru/forum/topic_11221 Наши результаты в CineBench. - Здесь выкладываем результаты в CineBench. http://acerfans.ru/forum/topic_10970 Наши результаты в WinAero WEI - Результаты тестирования. http://acerfans.ru/forum/topic_10985 Экраны блокировки Windows 10. http://acerfans.ru/forum/topic_10999 Наши помошники - Устройства измерения и диагностики. http://acerfans.ru/forum/topic_10971 Применение программатора CH341A - Практическое руководство. http://acerfans.ru/forum/topic_10910 |
1 мая 2018 20:38
#8586
Цитата: Wiew Believe me, if you change the partition layout, you will lose your original system or laptop Процесс простой : удалите лишние разделы, должно быть 5 заводских Win8, а затем перепишите атрибуты табеля GPT по умолчанию в diskpart, загрузив с внешнего DVD Windows 8. Но, не обязательно грузиться с внешнего носителя, все прекрасно прописывается в рабочей ОС, запустив ком строку от имени администратора. По проблеме: 1. В ком. строке от имени администратора прописываются следующие команды: diskpart sel disk 0 list part В списке разделов находим последний раздел - это и есть раздел PBR (7-й); далее вводим: sel part 7 set id="de94bba4-06d1-4d40-a16a-bfd50179d6ac" gpt attributes=0x8000000000000001 sel part 1 set id="de94bba4-06d1-4d40-a16a-bfd50179d6ac" gpt attributes=0x8000000000000001 exit reagentc /info здесь выводятся сведения о параметрах восстановления. Если функция "Disable", то вводим команду: reagentc /enable при необходимости указываем среду восстановления WindowsRE (она в первом разделе, файл ?\Recovery\WindowsRE\winre.wim) и образ заводской ОС (раздел PBR в папке RecoveryImage). Как это указать, можно узнать, набрав команду: reagentc /? где: setreimage - указывает на образ среды восстановления; setosimage - указывает на образ заводской ОС. После этого запускаем программу Acer eRecovery и создаем USB восстановления. Все. PS. Так как в конфигурационном файле раздел PBR прописан под номером 5, то он и должен быть пятым. Удаляем все лишние разделы. Если какой-либо из разделов скрыт и имеет определенный формат, не позволяющий удалить раздел в оснастке "управление дисками", то это можно выполнить в diskpart, например: diskpart sel disk 0 sel part 3 del part override exit Здесь указан лишний раздел 3 (для примера). #7523 |
3 мая 2018 08:31
#8587
tixo, Thank you for your help and desire. I found a solution for OKR Lenovo and I described them here https://www.fixitpc.pl/topic/33890-how-to-recover-lenovo-data-from-backup-one-ke y-recowery/ The FILE "WSI" CANNOT BE CHANGED, the program itself is based on this file creates partitions of tables. Solutions is left clean HDD with GPT system and no partition. AND barankin, beep-beep, The Internet does not have the limitations of language. You beep. И Баранкин, ***-*** вам, Интернет не имеют ограничения языка. Вы ***. Сообщение отредактировал reylby - 3 мая 2018 17:08 |
3 мая 2018 13:50
#8588
Цитата: Wiew Интернет не имеют ограничения языка Этот только русскоязычный! Читайте условия и правила!--------------------------------------------------------- ACER 5920G/T7700-2.4Ggz /4Gb/SSD256Gb/GF8600M GT512Mb/W10x64Pro ACER 5920G/T8300-2.4Ggz /4Gb/SSD256Gb/GF8600M GS512Mb/W10x64Pro ACER 5920G/T7500-2.2Ggz /4Gb/SSD256Gb/GF8600M GT512Mb/W10x64Pro Windows 11 - Решение проблем с установкой и настройкой. http://acerfans.ru/forum/topic_11221 Наши результаты в CineBench. - Здесь выкладываем результаты в CineBench. http://acerfans.ru/forum/topic_10970 Наши результаты в WinAero WEI - Результаты тестирования. http://acerfans.ru/forum/topic_10985 Экраны блокировки Windows 10. http://acerfans.ru/forum/topic_10999 Наши помошники - Устройства измерения и диагностики. http://acerfans.ru/forum/topic_10971 Применение программатора CH341A - Практическое руководство. http://acerfans.ru/forum/topic_10910 |
3 мая 2018 17:06
#8589
Wiew, barankin в данном конкретном случае прав, а Вы нет. Вы пришли на наш форум, просите помощи, но ведёте себя без уважения к собеседникам и правилам форума. У Интернета нет языковых ограничений благодаря онлайн-переводчикам, так воспользуйтесь же ими, когда пишете свои сообщения здесь. --------------------------------------------------------- И не надо мне писать письма или в личку по вопросам, связанным с ноутбуками, всё равно ж не отвечу;)) Всё это обсуждается на ФОРУМЕ. |
18 мая 2018 23:50
#8591
ooopppp, есть инструкция как восстановить 8 с флешки в картинках: тут но, режим БИОС должен быть для GPT : F2 - Boot - UEFI enabled Флешка MBR - выбор загрузки с флешки: Main F12 - Enabled жмем клавишу F12 и выбираем флешку в меню загрузки |
19 мая 2018 16:22
#8592
Репутация: 0 Сообщений: 29 |
tixo, Я так тоже делал. Появляется выбор языка клавиатуры, а затем 4 кнопки: Continue (exit and continue to win 8.1), Use a device (use a usb drive, network connection, or Windows recovery DVD), Troubleshoot, Turn off your PC. В Troubleshoot как обычно, резет с потерей и с сохранением, есть нажать любую их них, то предлагает сброситься до Windows 8.1 ! И есть кнопки дополнительных опций, нажав на которую есть 5 вариантов: system restore, system image recovery, automatic repair, command prompt, uefi firmware settings. |
20 мая 2018 00:01
#8593
Цитата: ooopppp предлагает сброситься до Windows 8.1 неправильно создана флешка - у вас заводская Win 8.0 (Создайте флешку вручную #5850) т.к. после обновления 8 на 8.1 - изменился порядок разделов и программа Acer Recovery не работает. Либо создайте флешку вручную, либо удалите лишние разделы и перепишите табель GPT см. #8587 Порядок заводских разделов GPT UEFI Windows 8 1. RECOVERY 2. EFI 3. MSR 4. Windows 5. Push Button Reset Сообщение отредактировал tixo - 20 мая 2018 00:45 |
20 мая 2018 04:17
#8594
tixo, Ммм, я флешку через Acer Recovery делал с hdd, где стоит заводская нетронутая win 8. На ssd с 8.1 у меня этой проги почему-то вообще нет и, вроде, не было на 8ке. Сообщение отредактировал ooopppp - 20 мая 2018 04:18 |
20 мая 2018 20:31
#8595
ooopppp, для нового SSD, загрузитесь с флешки и выберите пункт - Заново разбить диск на разделы (см инструкцию п.23) Сообщение отредактировал tixo - 20 мая 2018 20:32 |
20 мая 2018 22:38
#8596
tixo, Я извиняюсь, пункт 23 ? У меня нет такой опции, где я могу разбить диск на разделы, а по вашей ссылке в пункте 23 ошибка, которую мне и не удаётся миновать. |
20 мая 2018 23:54
#8597
ooopppp, п.23 - там автор надеялся на чудо, или попробуйте взять другого производителя 16 ГБ флешку Сообщение отредактировал tixo - 20 мая 2018 23:55 |
9 июня 2018 23:50
#8598
Репутация: 0 Сообщений: 31 |
Подскажите по восстановлению, ноутбук Packard Bell windows 8.1. Хочу сделать полное восстановление ОС до заводского состояния. D2D RECOVERY в биос включено, но при выборе восстановления до исходного состоянии вылетает ошибка об отсутствии раздела восстановления. Через администрирование в панели управления проверил, разделы все на месте, ничего не трогал. Полагаю это из-за обновления Windows 8 на 8.1 не работает теперь рекавери? |
10 июня 2018 00:07
#8599
Сообщение отредактировал tixo - 14 июня 2018 21:54 |
10 июня 2018 07:02
#8600
tixo, А как-то можно,сделать чтобы рекавери снова работало? У меня был файл, для Acer, но он для windows 7, а тут на windows 8 не работает |
Название темы | Автор |
Браузеры - Выбор, обсуждение и настройка различных браузеров | D1man |
Наши результаты в 3DMark | FuzzyL |
Проблемы с программами | FuzzyL |
Launch Manager и дополнительные кнопки - Установка, настройка и решение проблем | Ynikum |
Brazos Tweaker - частота и напряжение процессора на платформе AMD Brazos | minos66 |
Acer Empowering Technology - Установка, настройка и решение проблем с работой | cvetocheck |
Acronis Disk Director и Acronis True Image | b.o.dubb |
Как переназначить кнопки | winblade |
K10STAT. Обсуждение программы - Аналог RMClock для новых процессоров AMD | alpunka |
Выбор бесплатного программного обеспечения | FuzzyL |
